AC 15 and coordinates input
Hello!
I noticed one different thing than in previous versions.
In 14 or earlier versions, when I took wall for one of it's ends and start to stretch it and than press shift + "r" than I entered the value for which wall would be extended, but in 15 it goes for a overall length of it. In previous versions that would be the case only if I went with mouse over reference line of the wall and than press "r" and input desired value.
Is there possibility to change that in v15 to previous version?
29 Replies 29
I'm going to report this coordinate thing as a bug.
Then we will see if it was intentional or unintentional.
By the way, my experience tells me that many times when things change, it is because people have been asking for it, criticizing GS for the way it was working. Then it was changed and there is a new set of people who are now very dissatisfied.
I am not saying this is the case now but may be.
dirty wrote:
Has anyone else noticed that the 'Explode into Current View' command does not seem to explode polylines into lines anymore? I used to use this command interchangeably with the 'Unify' command to change lines to polylines and vice versa. But now it seems the operations only go one direction. I can still use the magic wand to place line segments on top of an existing polyline, but must go to the added step of deleting the original.
Yes, it does not work for me either in ArchiCAD 15.
This looks like a bug to me as it asks you if you want to keep the original element. Plus, it worked in AC14.
I will report this to GS.
MMontgomery
mzex wrote:
Hello!
I need this fixed as well - This is something I use constantly. The Alt+Shift complicates what used to feel like a very intuitive way of drawing/modelling.
AC 6-29 - Ryzen9 9950X / 96GB RAM / RTX 5090 / Win 11 Pro
Laura Yanoviak
laszlonagy wrote:
dirty wrote:
Has anyone else noticed that the 'Explode into Current View' command does not seem to explode polylines into lines anymore?...
Huh -- it worked for me yesterday, but not today
I swear there was a moment where I got it working right after I noticed the issue by re-entering the shortcut key I have set for this command. But the command stopped working again later and I couldn't get the shortcut key trick to work again. I just assumed I got confused and somehow opened an AC-14 window by accident.
Suspending / enabling groups had no effect for me.
I just noticed that if you throw a curved segment into the polyline the whole thing explodes properly into lines again. Has to be a glitch.
Thanks for reporting, laszlonagy.
Yes, the same here.
If there is a curved segment in the Polyline, it properly explodes into lines and arcs.
If it has straight segments only, it actually explodes into another polyline, which is grouped by itself.
Works in AC14 and prior.
For exploding polylines...
an intermediate solution (other than adding a curved segment) is to use linework consolidation and select explode polylines into drawing primitives.
I've got a shortcut for linework consolidation, so it's not too much of a hassle, but it's still worse than just exploding.
Anyways seems like I shouldn't feel bad that I haven't had time to migrate my template or start a project in v15 yet! Well I hope a hotfix comes soon.
Jared Banks, AIA
Shoegnome Architects
Good suggestion. I've got it on quick key now.
MarinRacic
MMontgomery wrote:
mzex wrote:
Hello!
Let's just not forget about this shortcut issue...
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
Do you know that you can change in the operating system settings which key combination should toggle between the keyboard layouts? If you disable it it will not interfere with ArchiCAD's ALT+SHIFT.
This, by the way, has been a problem for many-many years.
I myself have disabled this feature of the system (have not defined any key combination for it).
In the Region and Language Control Panel, you can go to the Keyboard and Languages tab page, click the Change keyboards button.
Then in the Text Services and Input Languages Dialog, go to the Advanced Key Settings tab page click the Change Key Sequence button.
Then choose the "Not Assigned" radio button for the "Switch Input Language" field.
So as you can see it is an obvious option, nicely hidden in a sub-sub-sub-dialog of the operating system.
