AC 22 Vectorial Hatching Doesn't Appear in Elevations and Sections
EH21
New issue on AC22. See images. This example is for an exterior wall, but it is happening with roofs and slabs as well.
When the exterior surface is defined, the vectorial hatching (which should appear as shingles) will only appear on sections and elevations when the wall end or roof side material is also defined as the same material. However, when the end material is changed, it also makes the vectorial hatching associated with the exterior material appear on the interior.
No graphic overrides are set, and I've gone through every setting I can think of.
Help!!
EH21
Thank you! I did manage to figure out the issue. The section view settings were only set to view the core elements and not the finish surfaces of the walls.
Podolsky
Ace
I guess here only two options: first, this is a bug (but I never experienced it); second - your wall is set the way, that exterior surface is inside and interior - outside. Flip the wall - maybe it will work then.
EH21
Thanks for posting back with the solution.
