AC11 Little improvements......
Wanted to start a list of AC11 Little improvements......which are not announced:
First Selection outline now is shown in dots
Second Selection outline is shown in Dot Dash Dot
Nice, yet still short cut C for changing of the method is still not implemented, must be very hard to code it in!
Joseph
143 Replies 143
Mark wrote:
Mark wrote:
In version 11 I am my "Preview Options" for objets does not work. Anyone Else?
Thanks,
Mark Hendricks
Wow, It's been a long day. Let me rewrite that:
In Version11 my "Preview Options" for objects does not work.
Anyone Else?
Thanks,
Mark Hendricks
OK, I closed Archicad 11 and restarted. Now I have "Preview Options". Maybe a graphics card issue.
Thanks,
Mark Hendricks
Link
You know you can edit your own posts?
Maybe you have the Library Part Browser hidden in your WE?
Link.
It is not the point in WE options.
I noticed the same after some time of working in AC 11 - previews of gdl objects are gone - when AC 11 is restarted they are back - but they are gone after some time again.
I reported this issue during the test (2 or 3 times reported) - but it did not receive the "killer" status, unfortunately.... ;-(
It may well be a graphics card issue - but nothing like that hapen in 10.
I use Ati Radeon Mobile 9600 with the latest drivers.
Best Regards,
Piotr
Best Regards,
Piotr
This is exactly what happened to me several times. I'm glad to hear it's not just my machine.
Thanks,
The "edited" Mark Hendricks
Rakela Raul
http://www.archicadwiki.com/Bugs/Drawings_with_images_do_not_print
This is fixed in AC11
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Stephen Dolbee
I don't know if this is a similar problem or not. The "Basin Cabinet11" object behaves oddly. If placed at 0 degrees, it prints fine. If placed at an angle (90, 180, 270) the sink does not print, although it shows on-screen. Maybe it is just a problem with this library part?
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Steve
Have you tried it on different printers? I have found HP, Epson and Canon to be the most trouble free.
Stephen Dolbee
Yes. On my Canon at home and the HP at the office.
Rakela Raul
steve, i just tried it and it does plot work x me
edit: HP 4000
You could try printing to PDF (roughly equivalent to using a Postscript printer) sometimes this works better. It might be interesting to see if the same happens with plotting (plot to a file and open the HPGL).
Worst case, you may have to draw the sinks on unless/until this gets sorted.
