AC15 Annoyances
sedley
1. No Special Snap Points on Guidelines.
2. When you set the Pet Palette to follow the cursor, the Pet Palette disappear when working on Complex Roof and Shell tools.
I hope these are bugs and will be fix in the first update.
Sedley Jeffers
St.Vincent & the Grenadines
Archicad 26 Full USA - Cadimage & Twinmotion
MacBook Pro M1 16", 64GB RAM. OSX Monterey
I found if you keep holding the mouse button you can move to the pet pallet, and then release the mouse button when over the desired function.
Remember that a guideline has infinite length - therefore no end or mid points.
They will show intersections and if you have the special snap points set to show between intersections you will see mid-points, divisions, etc. between those intersecting points on the guide line.
Guide segments will have end and mid-points but these are not drawn automatically - you have to place them.
The pet palette is a bug that i hope is fixed in the downloadable version (build 3006).
The version you have on CD is build 3002 I believe.
The pet palette also doesn't always remember the last command you used.
I am running 3006 and it is not fixed.
