jakubc7
ARCHICAD 19 label renovation filter
I have been having an issue when placing associated labels in v19. When I select the label tool, renovation filter is selected to NEW. However when I place the label, it is created as EXISTING.
The only way I could work around this is to change the phase on the RENOVATIONS PALLET to DEMO or EXISTING and back to NEW prior to placing the label. Or simply changing the RENO to NEW after placing, which is quite frustrating.
At first I thought that it may be a side effect from using an old template, however after trying a new file using AUS TEMPLATE v19 and default favourites, I can confirm this is not resolved.
Has anyone had the same issue or been able to resolve it.
Since I am on the subject of labels. Why is it that when using "Identification Label 19" with frame ON (such is in a circle or square) the ID text appears slightly but very noticeably off centre?
Jakub
AC19 6006 (and previous builds) / WINDOWS 7 and 10
ArchiCAD 10 - 29 | Windows 11
Lucid Design Studio | Perth, Western Australia
0 Replies 0
