slab icon
Hi there when I choose the slab icon in archicad 19, i have noticed there is no icons at the top of the screen that suggest that I can choose how to obtain the type of shape the slab will be delivered i.e separate node form or box form. There are usually three options to choose from at the top of the screen. Can you help me with this I have checked the tool box situation also but to know avail.
Any help will be much appreciated cheers
paul
5 Replies 5
Is this happening with the slab tool only or with all tools?
hi the only thing changing is the gravity icon nothing else. i click any of the icons on the left tool box once and nothing is changing except the gravity icon turning on and off as i go through them. i have checked the panel preview and all nessacery eye lids are open
Sounds like you might have turned the Info box off.
To turn it back on ... WINDOWS menu > Palettes > Info box
Yep I think that is.
thank you very much problem solved
