How to make a wooden facade with angles
Hi all,
Does anyone have an idea on how to realise the picture below?
https://nl.pinterest.com/pin/355221489340698858/
4 Replies 4
Erwin Edel
Roofs, collumns, wall segments, complex profile walls, objects, etc etc there are a lot of different ways to create those wooden strips. If it repeats, save a segment as module and place the module as needed.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thnx for mentioning the options. But I still wouldn't know which steps to take to create one segment of 5m wide x 8 - 8,5m high.
Erwin Edel
Well, let's use the option of slanted collumns.
Draw the zig/zag snap-line/help-line in elevation with morph tool single line as a 3d snappoint, offset that from your facade by about 300 mm. place collumns with the dimension of the wooden strips. Go to 3D window and move the top hotspot of the collumnm to your guideline.
They are just strips of wood, you can model them with a lot of tools, all you need is to decide where you want them to have the bend.
www.leloup.nl
HERO! thnx!
