clauds1223
How to create hollow timber seat
Hi there,
How would I create a hollow section seat like below using the slab tool? Or what is the best way to do this?
Thanks,
3 Replies 3
2 slabs (top and bottom) and walls for the sides.
Or create a complex profile and use the wall or beam tool and cap the ends with separate walls.
Lingwisyer
Guru
I would use a Segemented Beam with a Complex Profile. Rectrangle, hollow CP, rectangle.
ps. Unless you need to do a cabinetry section as the joint lines will meld, even when the layer is set to Intersection Group Zero.
I always forget about the segmented beams.
Perfect for this.
