ARCHICAD 20 Update 3016 is available
mtron
Dear All,
Today we have released the ARCHICAD 20 Update build 3016. This Update corrects the recently discovered performance issue with the use of external images and Trace&Reference.
- This Update is available only for the following language versions: INT, USA, UKI, GER, AUT, FRA
- This is an ARCHICAD and OSX only Update, so there is no Windows version, and there is no BIM Server / BIMcloud Update.
- BIM Server/BIMcloud 20 Release Build 3012 is compatible with the updated ARCHICAD 20.
- All other (yet unreleased) language versions of ARCHICAD 20 contain this fix by default.
To read the Release Notes and download the update package use the below link:
ARCHICAD 20 Update 3016 (OS X only)
Best Regards,
Marti
MÔrta Trón
Technical Support
GRAPHISOFT
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
1 REPLY 1
DGSketcher
Legend
Thanks for the QUICK fix! Just about to start a new project with a lot of PDF bitmap references.
