‎2019-04-16 12:44 PM
‎2019-06-05 01:34 PM
Lasse wrote:Hi,
Were experiencing lots of unexpected crashing with 22:5009 SWE. Any date for 6000 SWE release?
It's getting a bit nervous here among our users.
‎2019-06-06 01:13 PM
DGSketcher wrote:Hi,
This doesn't work in AC22 6000 using profiled butt glazed frames. Gaps appear between the panels which can't be adjusted....
https://helpcenter.graphisoft.com/knowledgebase/84673/
‎2019-06-06 01:24 PM
Rectangular Window Opening 22 shows a tapered head lining when using the variable closure. This may apply to all windows using this option. The result is also present in 3D and was also flagged up in an IFC export by the recipient.
‎2019-06-06 01:28 PM
APA wrote:Hi,
I've you got an idea of the date of release ?
The beta is not available in French, and the 5000 version is the very very buggy
The search and find function alone makes at least 3 crash a day for Avery architects of our company !
Honestly, working 4 months with the 5000 version is the worst archicad experience I never had in a decade.
FYI : we work on mac.
‎2019-06-12 10:03 AM
dkovacs wrote:Hi, thx for your concerns !
Could you send me the bug IDs of some of those find and select crashes, so that I can take a look?
I want to see if it is a known issue, and if it is going to be fixed in the 6000 update.
Also, did you experience the same in build 40xx, or it started 50xx?
Thanks,
‎2019-06-12 11:56 AM
‎2019-06-12 01:33 PM
‎2019-06-25 03:38 PM
‎2019-06-25 09:53 PM
‎2019-06-27 05:55 PM
