2021-05-27 08:35 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-06-08 12:16 PM
2021-06-08 02:47 PM
DGSketcher wrote:We found that this is a rare bug with the editing plane. For some reason, the absolute/relative button affects the location of the vertical editing plane of this interaction and when it's set to absolute, it makes the plane to be at the origin. It is registered as defect DEF-5299. As a workaround, please set the Editing Plane to be Horizontal from the context menu, or simply use Shift+E.
Beam length stretching in 3D is broken in this update. You can move the endpoint as a workaround, but you can't simply extend the beam along its axis. This appears to be a legacy data problem. Creating a new beam in a new file works ok. I have a sample beam that fails trapped in a .MOD file if GS would like me to upload it.
Minh Nguyen
GRAPHISOFT
