Accessing design menu
Hello.
I'm sry if I'm posting in the wrong subforum.
I have a problem with accessing the design menu in Archicad 13. I'm doing as the tutorial is showing but i dent have design menu at all. I tried the toolbar settings and work environment settings but i cant find a place where to access design menu.
Can anyone direct me to design menu switch or tell me what i should to in order to access design menu.
Regards
Priit
I dont know why but the problem solved when i opened a new project with default settings...
Mystery but yet i am a rookie...
This should probably be posted in the "Working in ArchiCAD" forum. It does not belong in the wish list. Only post here if you are pretty sure that what you are requesting is not already in the program.
You can restore the design menu by resetting the Work Environment (see the Options menu). For more info on Work Environments search the forum and the WIKI and check the manual.
