Geof Gainer
Design Options menu item not showing up
I skipped AC27 and just installed AC28. I'm in Menus in the Work Environment adding new features. Keynotes was there, but the Design Options menu item is not showing up. Any idea why not?
Also, it's nice being able to choose "all new commands in alphabetical order", but they're just for AC28 of course. Is there a way to find the AC27 list?
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
4 Replies 4
Lingwisyer
Guru
Just type in the search bar? It's not new anymore so it is not surprising that it does not show up with that filter. Finally having a search bar for all of these lists is amazing and you have to wonder who in the right mind decided to not include one originally...
Or open 27 and see what was new in there.
But just searching for keywords is good.
Just make sure you are looking in 'all commands in alphabetical order' - not all NEW commands in alphabetical order'.
Geof Gainer
Thanks, I figured I'd better just revert to Standard Commands 28—I hadn't tweaked the menus much.
Lingwisyer
Guru
They really should make it that new things are on / visible by default when you migrate your settings...
