Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Accessories
How do you get the roof accessories to work in the AC15 trial on Windows 7? Specifically the metal roofing.
I can see "Accessories" in the Design Tool menu but it is grayed out.
Thanks
6 REPLIES 6
Is the AccessoriesLibrary 15.lcf loaded? Check with Library Manager.
It doesn't appear to be. There is an Object Library 15.icf. That is all that is in the ArchiCAD Library 15 folder too. Where is this library located?
Thanks
Win 7 AC15 trial
In the folder "Accessories Library 15", and is .lcf not .icf!
Thanks andro,
I guess for whatever reason this library must not be available in the trial. I've tried reinstalling and still no such library.
David Maudlin
Jeffrey:
Go to Help > ArchiCAD 15 Downloads and download the Accessories Goodie. After installation the Accessories Library 15 will be added to the ArchiCAD 15 folder.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David, never would have found it otherwise as I can't find anything about in the documentation.
