Add *only* to selection
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2021-03-16 04:16 PM
ā2021-03-16
04:16 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-03-17 02:27 AM
ā2021-03-17
02:27 AM
Of course it all depends on just how complex a jumble of elements are that you are trying to select.
But some things that may help.
As you mentioned just SHIFT+click to add new elements - don't drag a selection box.
Let go of everything and drag a new larger selection box.
Don't forget the selection area does not have to be a box - it can be an irregular polygon.
Also there is the left to right = select all partly inside the selection area, and right to left = select only entirely within selection area (I might have that around the wrong way) - this may help to select just particular elements.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-03-17 03:14 PM
ā2021-03-17
03:14 PM
One other thing that you could try is the Selections Palette. I don't use it that often myself, but when I do more complex selections, it does come in handy.
Like Barry said, it depends on how complex your selection is, so it might be overkill to use Selections Palette... But anyway, in your case, you could do your first selection, save it in the Selections Palette and then just making the second selection (without Shift) and in the palette just clicking on the plus button.
