Adding composites
hey I have another question. I already made my walls, now i figured out i will need to add another composite to it. So i made my own composite-wall. With adding composite to a wall, it off course changes it's thickness. But when i change my existing external walls with my composite-wall the wall stretches INSIDE my ground-floor plan, over my internal objects.. so i wonder, is it possible, to make your walls thicker and they only expand on outside? And how to do it, without moving each wall
thanks a lot guys! Appreciate it
You can do it by changing position of the Wall Reference line.
Example: external wall is 30cm thick and reference line is 10cm from internal side. When you change this wall with new composite wall 40cm thick, set its reference line 10cm from internal side. In this way the wall expand outside.
rocorona
You can also try setting a displacement for the affected walls, equal to the thickness of the new composite layer.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
