Adjusting window sidelight parameters
I'm trying amend a window with sidelights either side.
I know the door leaf size (762 x1981) so I set this in the window settings.
I then want to be able to drag the sidelights to the correct size whilst retaining the door leaf size.
At the mo, the only way I can see to do this is by manually entering the sidelight width into the parameters.
Is there a way to select the handle and drag it??
All advice appreciated.
Regards,
Tom.
1 REPLY 1
It depends on the library part. If it was written for dynamic sidelight adjustment then yes, otherwise no. If yes there will be distinct hotspots in plan and/or 3D for the purpose.
