‎2008-09-10
03:06 AM
‎2023-05-23
04:59 PM
Rubia Torres
‎2008-09-15 08:57 PM
‎2008-09-15 09:35 PM
‎2008-09-16 09:53 AM
‎2008-09-16 03:50 PM
‎2008-09-16 04:05 PM
tsturm wrote:I think you just run it. It should work without problems, but you should use the most recent Combo update (it updates all versions of 10.4 to 10.4.11). This is the most thorough update of the system you can do short of re-installing.
Thomas
How do you re-apply a downloaded update?
‎2008-09-17 01:33 PM
Thomas wrote:Same place, but the button is called "Modifier Keys...", there is nothing application specific here, so that would not explain why they work in other applications, also the Shift key is not shown here.
Did you check your System prefs? In Leopard, in the Keyboard pane, there is a button at the bottom that says "Special keys". There, for each or for all keyboards, you can set the actions wanted for each modifier key. I'm not sure where this is located in Tiger anymore, but it's there somewhere.
‎2008-09-17 05:17 PM
‎2008-09-18 06:47 AM
‎2008-09-26 01:49 PM
