‎2008-04-07 10:59 PM
‎2008-04-07 11:04 PM
‎2008-04-08 12:13 AM
‎2008-04-08 11:16 AM
Phoevos wrote:Yes, if you don't plan to change their position excessively. If you do, better to use SOE (Solid Element Operations) with the floor as operator and the walls as target. The trim will then auto-update when you move any part.
Thank you for your quick reply! Would the correct method then be to trim walls' top and bottom to the angled roofs / "floors" ?
‎2008-04-08 05:48 PM
‎2008-04-08 09:57 PM
Chazz wrote:3D Cut in Top View isn't too bad either.
Always though, the tricky thing with models of this type is how to represent them convincingly and literally in formal 2D floor plans. Here, the overly hard-to-use Floor Plan Cut Plane tool is recommended as is an abundance of 3d views. Maybe a keyplan/section view that shows where the horizontal slices are being made would help too.
‎2008-04-09 04:33 PM
Phoevos wrote:You
Hello, I am a newish Archicad user, and I have made this model in Sketchup. I was wondering what the best way would be to model it in Archicad. I cannot seem to find an easy way to slant floors and walls to create the shapes.
‎2008-04-09 06:13 PM
Laura wrote:by the way .. now that we have slanted walls , shouldn't SU plug in stop translating every thing as roofs?
Youcouldimport the Sketchup model into ArchiCAD to get an idea of the elements involved and their geometries (although it is best to ultimately model in AC).
‎2008-04-16 05:09 PM
