Annoying new text anchors in AC13
kevin b
Anyone know if there is a way to turn of the new "feature" that shows the anchor point of text blocks and leaders as a big bold "+" without turning off the handles? Or a way to change them to be less annoying (ie less bold, diff color) I can't find anything about controling them. I can't even find anything describing them as a new "feature."
Anyone else out there like them? Hate them?
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
22 REPLIES 22
I wonder if the attached solution might be a neater way of marking the anchor points? (Original at bottom for comparison)
I'd be happy with that. Thanks, Peter.
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
I don't mind the single pixel anchors (did they thin them down in 14?) but why can't you snap to them when they are not at the corners? Interesting that the automatic Element Snap works on, say, centre top anchor, but an ordinary snap for drawing something like a line does not.
