Tazo Kikoria
Arch Top Openings in the Segmented Curved Walls
Hello
I have a wide arch top window in my project and I want it to occupy three segments of the wall:
When I place the Opening as a tool it can't cover all the three segments with the geometry I'm willing to. When I use Arch Top Empty Opening it can't be placed on more than one wall so the only thing I could do was to place three arch top window openings and try to merge them but as you can see it's not clean and exact:
Setup info provided by author
1 Reply 1
cuba
Since you are working with a curtain wall behind the façade, you can also create an opening using the Opening tool, or by means of SEO operations by shaping it as a complex profile.
Apple M1 Max 32 GB
Latest AC
