Arched top window over a slider?
I need a 4020fixed with a full arch over a 4040slider. I can't find an arched top window that has a slider under it. All the ones in the library and on BIMcomponents don't have the slider option. They are all casement.
I tried to use the W Half Round Fixed 20 placed over a slider. This window mandates a 4' wide arch be 2'-4" tall. I need it to be 2'-0" tall.
Does anyone have an object or workaround that works for this?
Loren CadImage's Door & Window Builder can do this easily but that is an add-on. You can try it out for free for 30 days I believe if you want to try it.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
