Eric Graas
ArchiCAD 16 Create Landing
I am trying to create a residential wood stair with a landing as the first stair. The first stair has a 90 degree turn from the rest of the run. 3'-6" wide stair - 4'-0" wide landing (if possible in a perfect world) floor to floor= 9'-1". From what I can find, the minimum number of risers you can have for a run is 2 (one stair tread - two risers - then the landing). Any help with this would be appreciated.
3 Replies 3
The easiest way to handle it is to model the landing with slabs and then just start the stair from there.
Eric Graas
Modeling the landing separately is the easiest way for modeling purposes, but the floorplan would not correlate. I thought I would throw this question out in case anyone had come across this issue before.
Dwight
Study the possibility of using the "Create Stair from Selection" feature under Design.
Dwight Atkinson
