ArchiCAD + Thin clients + Terminal server
does anyone have an experience with running the ArchiCAD on a terminal server + thin clients? Is it supported solution?
Our customer requests to deploy the secure ArchiCAD solution with protection of his investments. Now, he is running typical infrastructure with graphical workstations and one BIM server. We would like to replace 10 graphical workstations by thin clients and add one powerful terminal server. We've tested working with ArchiCAD via Microsoft Remote Desktop, but it is not so comfortable as a graphical workstation.
Thanks in advance for any opinions.
Rob
AFAIK thin clients/terminal server is not supported.
if you need remote connection for licensing go for license borrowing scheme off the central net dongle. I would suggest to contact GS reseller in your country.
::rk
I use it in a terminal sever session and it works great!
Arch
