ā2007-11-14
01:42 AM
ā2023-05-25
05:35 PM
Rubia Torres
ā2007-11-14 01:53 AM
ā2007-11-14 03:31 AM
ā2007-11-14 03:40 AM
ā2007-11-14 02:36 PM
ā2007-11-14 07:29 PM
ā2007-11-14 09:32 PM
seattleguy wrote:the thing you should know about archicad stairs is that there is no solution that works all of the time. i have both archistair and stairbuilder, as well as the library stair objects and - at a very last resort - the built in stairmaker. NONE are truly fit for purpose, although each of them have their strengths . . .
So if it came down to ArchiStair or Stair Builder... which should I get?
ā2007-11-14 09:47 PM
ā2007-11-14 10:37 PM
~/archiben wrote:NONE will produce an ADA compliant stair. After numerous hours playing with SB, AS, and the AC stair tools, my conclusion is to skip the additional cost and hassles of an add-on. ALL methods require 2D work arounds for documentation.
ā2007-11-14 11:06 PM
Laura wrote:I assume you are talking about handrail returns, which can be an issue. The actual stair component can certainly be made ADA compliant. To document compliance "the BIM way" I have, in the past, used StairBuilder in conjunction with CadImage's 3D Profiler for the handrails, which is sort of fun to use.
