Archicad 12 object disply issue
Hello Friends..
Recently I got issue with my archicad 12 objects display Issue. When I draft the objects (wall lines, etc) the display was not good. please see on attached image. Can any one please help, do I change any settings or else?
3 REPLIES 3
I'd be guessing you have turned off the Vectorial Fills.
VIEW menu > On screen display options > Vectorial fills.
Seems like your drawing lacks line weight variation.
Look at the >On Screen Options >Bold Cut Lines.
Please indicate the AC version and OS in the signature box of your forum profile.
Snap
MMontgomery
Check to see if turning on 'True Line Weight' achieves the result you want.
Also in On-Screen View Options > True Line Weight
AC 6-27 - Intel i9-9900K - RTX3090 - Windows 11 - 64GB RAM
