‎2022-02-09 06:31 AM
Hey guys. A friend shared a project with me but he is using Archicad 24. I use Arch22. It tells me it can't read the file. How can I fix this?
Thanks in advance
‎2022-02-09 06:49 AM
Version 22 can not open files created in version 24.
You either need to use 24 or you will have to get your friend to 'save as' a version 23 file.
Then they will have to open in 23 and 'save as' a version 22 file.
Files can be back-saved only one version at a time and you need each version installed to do it.
Also you will lose any information if it is using a new feature in 24 that is not available in 22.
