We value your input! Please participate in Archicad 28 Home Screen and Tooltips/Quick Tutorials survey
2021-07-27 04:39 AM - last edited on 2023-05-09 04:15 PM by Rubia Torres
2021-09-08 02:05 PM - edited 2021-09-08 02:05 PM
Hi Barry,
Yes, the packages were available on the website before Check for Updates was enabled. We were waiting for some components before making it happened (but now it should notice you about the update). Yes, this update address the defect causing file size issue, so we strongly advise updating to this build as soon as possible if you are working on Archicad 25.
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-11-17 08:28 PM
A colleague has experienced the same issue and a file of my own has just jumped from 100mb to 850mb in a single save from AC24 to AC25. No problems with AC25 files, only those saving from previous versions. We have sent a file to Graphisoft but only workaround seems to be copying everything into new AC25 file.
2021-11-17 09:24 PM
Hello,
Thank you for the report and I am very sorry to hear about this!
The issue has been fixed in the first update for Archicad 25. In order to avoid this issue in the future, I strongly suggest updating to the latest build (which is 4013). Any files that increase significantly in size, please feel free to contact the local support for further investigation - I'm sure that if it is related to defect DEF-6049, then we will be able to fix it easily.
Thank you very much for your understanding!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
