Narska
Archicad 25
Where can I find a list of what new goodies we can expect in the next version of archicad?
Tomasz Mlynarski
New York based Architect
184 Replies 184
Podolsky
Ace
DGSketcher wrote:
Just a little reminder, Sketchup was in the hands of Google for six years and they pretty much did nothing to really develop it from more than a basic modeller. The documenting process was and is I believe still a mess.
On the Autode$k issue, did the letter make any difference? Have they actually genuinely changed direction? I doubt it, they hold a monopolistic position. There are too many hollow apologists on this planet just now, "oh we're sorry, we won't do it again and we will learn from what you are saying.", yeah, right up until the next shareholder meeting.
I agree AC25 so far has been a disaster, but take a close look at the competition and compare the stuff that works in AC against other software. If the other software does the job better then you have a choice. If it doesn't the best that can be done is to air your opinion and ride it out.
Then guys, close your design offices. We are facing to global crisis with AEC software worldwide. No point to argue. Switch to hand drawings and calculators - less problems, no crashes, total control of tools and freedom for creativity. Drafting board was created for architects by architects. And almost for free - only expenses for buying pens, paper, tracing paper... Also hand manipulations helps to develop intellect, when pressing buttons and clicking with a mouse I started doubting that is - maybe even have opposite effect, if situation with AEC is so damn and nobody understand anymore what's going on.
"Another day, another manufactured crisis keeping people distracted"
Agreed. And just check their Road Map Ground Rules.
DGSketcher
Legend
Ahh yes the good old days of blunt pencils, clogged ink pens, worn & torn vellum, redraws that took a bit longer than a few seconds, ammonia based copiers...
Podolsky
Ace
Exactly. Imagine you draw on paper and suddenly without the reason your paper started to burn and all your work disappearing. You are calling to the company who sold you paper and saying - my paper burned out! - Ah, yes, this is paper bug, please collect all ashes and send to our laboratory. And you do that every bloody day for 3 months. Until you are getting respond from laboratory - "we have figured out, that type of wood in your drafting board is causing fire with this sort of paper. thank you for cooperation"
jl_lt
Ace
Fire due to friction for drawing too fast?
Podolsky
Ace
No, because we had gaming thoughts instead of professional while we drew, and we need to update our glasses too, due incapacity of drafting board wood material, type of paper and glasses in between.
This is a simplistic (and uncharitable) assessment of Google's period of ownership and custodianship of Sketchup, that undercuts a lot things that happened and gained by the program.
Granted, it probably wasn't the most prudent of investments given where they wanted to take the program compred to where they eventually ended up, but under Google, Sketchup gained the Google (now Trimble) 3D warehouse which is the largest repository of crowdsourced 3D modeled objects from all manner of areas in life - and which are used extensively even with programs and areas other than Sketchup (including ArchiCAD itself).
And let's not forget that Graphisoft themselve tried to emulate this initiative with their own BIMcomponents portal, that had......shall we say....mixed results, but nowhere near the same level of success due to them doing things the Graphisoft-ey way (cart before the horse.)
Also an offshoot from the Google ownership was the massive global crowdsourcing of 3D constructed buildings around the world that they would then use to populate their Google 3D maps - at the time - before they switched methodologies to photogrammetry and other means of getting digital 3D information for their map.
But out of that, you had some cities and municipalities take advantage of it, and digitize and update their own city 3D maps and databases using those Sketchup models and which to this day are useful for a lot of architects and designers in saving time (where your city authorities were astute and 'on-the--ball' enough to build those databases).
They eventually sold it off to Trimble (for a good price given what they built into it) - which in retrospect was a wise choice since they weren't a good fit, based on what they had hoped to get out of Sketchup versus where they actually wanted to go. Trimble is more closely aligned to the AEC industry and to the extent that Sketchup has seen any major improvements or developments since they bought it out, it lies more at their doorstep since they would be more attuned to what the users want than Google ever could be.
Or at least theoretically should be.
It's not just about having the financial heft and resources to carry out the needed developmental changes.
Its also about knowing how best to spend those resources by knowing what needs getting done.
DGSketcher wrote:
On the Autode$k issue, did the letter make any difference? Have they actually genuinely changed direction? I doubt it, they hold a monopolistic position. There are too many hollow apologists on this planet just now, "oh we're sorry, we won't do it again and we will learn from what you are saying.", yeah, right up until the next shareholder meeting....
Short answer is yes, it did (...in the short term. ....and with caveats) have an effect, and made a differnce with Autodesk.
One of the main ones being they've become very proactive in their customer interactions and regarding future development plans (including the publishing of roadmaps - which, we here can only dream of), and emblemified by their establishment of a Trello board for direct customer interaction with, and even a peek into what developers are working on.
Trello boards are commonplace these days with Software development companies - or some versions ofthe concept (McNeel has the Serengeti forum in which the principle is the same. You get to interact with developers and get a sneek peek at beta versions and WIP version and have open back-and-forth dialogs and most importantly direct feedback for them before features are locked in. Think of how much that could have saved GS with a lot of the...how shall we say,...half-baked...features in this most recent release that seemed like they were missing just that extra level of user feedback that the Beta process seems to be failing in providing them).
AS to real concrete comprehensive changes to their system and the programs themselves, we'll have to wait and see the next versions next year which will be the first developed under this open system of back and forth with users, and check to see if they actually take anything on board.
But the implementation of the Trello board itself, and having not just actual developers, but Development heads in constant dialog with not just users but everyday users (and not exclusive the "Key client" types and insider clubs), is a good first step for them, if not a show of good faith that they're listening...
....AND responding
Can we say the same here?
This is not to say that a similar letter will work the same way on this side.
For the one thing, we certainly don't have the weight of the big name architects and customers like the Fosters and the Zaha Hadid's to sign on to it and bring along with it the glaring media coverage that Autodesk just couldn't run away from.
For another, all that negative media attention had a knock-on effect because Autodesk is a publicly traded company.
With shareholders.
To answer to.
Who don't like bad reports and press clippings, that tank stock prices and ruin their financial portfolios.
Clearly, with ArchiCAD the situation is different.
To whom would the letter be?
Graphisoft?
But they're owned by Nemetschek.
And Nemetschek themselves are serving more in the role of a 'holding' company for all the subsidiaries they own (Maxon, Vectorworks makers, Allpan...) rather than one that's actively involved in the administrative procedures of each company.
So how effective would a letter like that be to them even with any negative press coverage it could bring in its wake?
Podolsky
Ace
My point about the letter signed at least of ArchiCAD Talk forum members - at least to show self dignity. It's more civilized way to show that users are disappointed on the last years releases, instead of showing frustrations and turn the forum into bazaar of angry people, who are already were exhausted by COVID, problems with running projects, bugs, crashes, technological incompatibilities of different parts of software, lack of direct communication with developers, poor support of national CAD standards and many more.
Instead of that to prepare more structured list of concerns.
The letter probably must be addressed to Graphisoft. To CEO of Graphisoft - that was his words in interview that Graphisoft is planning to make ArchiCAD architectural software number one. Possibly to Gabor Boyar too - as many architects were amazed by his invention and technology introduced in ArchiCAD, but seems something went wrong somewhere, and where all that goes - big question mark. It definitely moves in some direction, but is that direction the same what users are expecting, or we must continue wait for important features, needed today, for 10 years, as that happened at least with morph and now with survey point.
Some people can disagree with me. I had very long 'relationship' with ArchiCAD, starting as one of the first ArchiCAD users in Lithuania - just because for me only this software did make sense in architecture, then working in ArchiCAD distribution company in Vilnius and Moscow, also working in 'top' ArchiCAD driven architectural companies in London, finally using ArchiCAD in construction company and developing quite unique template and library, trying to achieve Level of Details 5 in my work and providing digital twins directly on construction site. In total very different 20+ years long ArchiCAD journey brought me to conclusion, that Graphisoft could provide and better software and better services for their customers, but why this is still not happening - it's one of the largest questions I'm not able to find answer.
Can we find out - who is 'guilty' in that situation? What, Autodesk? First, a war with AutoCAD and after war with Revit? But AutoCAD and Revit are not able to deliver the same quality of models. Or just it's overall lack of vision of future and nobody really knows how BIM application must look like, because we never had anything like that in the whole history of architecture? Or maybe Graphisoft simply need a person, someone like Steve Jobs was for Apple, who rised the company to the hights where they are now?
insideru
Don't forget Nemetschek. They also have Allplan and Vectorworks. I don't think Graphisoft does as it pleases. They must make sure all solutions make place in the marketplace, same way Apple f***s their iPad Pro users by making sure they are not cannibalizing sales of their Mac lines.
ARCHICAD 28 INT
macOS Sequoia
Podolsky
Ace
I think Nemetschek are shareholders. They bought 80% of market share or something. But Graphisoft is still autonomous company. They have their park, offices, staff...
