rob-faam
Archicad 28 update 6003 > Crash on copying parts from a hotlinked module
Since the 6003 update, Archicad crashes when trying to copy parts from a hotlinked module.
(Groups suspended > select one or more elements from the hotlink > ctrl+c > ctrl+v > crash)
Please fix this urgently!
Operating system used: Windows 11 23H2
Setup info provided by author
13 Replies 13
Bawar Tanay
We have the exact same problem.
We are using the iceberg  method in a teamwork file.
Will let you know if above resolves the issue.
Archicad 16 - 28
Laptop: Alienware M18 R1 | windows 11 pro | i9-13900HX | RTX 4070 8 GB | 32 GB RAM
rob-faam
I think it has to do with the global library. Some of our files use some older 27 library parts that maybe conflict with the 28 global library.
The problem was fixed with update to 28.2, now with 28.3 the problem is reoccuring.
Another reason maybe not to mix libraries (unless the old objects are your own custom objects).
Use either the 27 or 28/29 libraries, but not both at the same time.
Barry,
cagarruta
Hello again, problem resolved!
After a lot of trial and error, in our case, the issue was with Archicad classifications.
We erased the classifications we knew we didn't use, generated new HLM, updated the Host and closed the file. Afterwards we opened the file and it worked. I believe there was a conflict in the blurred classifications.
Ill hope work for you
Note: Something similar maybe occur with properties
Archicad 25 SPA v6000
i9 14900K/32 Gb DDR4/1TB SSD/10GBPS Lan/Windows 11 PRO
