Archicad - 3d visualization
Hello everyone:
Im having some troubles making clean 3d views.
1) In this model i want to hide that line (the top form is a morph to create the roof, while the rest is a normal wall).
2) In the rail of the second floor front window if possible i would want to show the segments of the tubular bars
This is usually a problem i have with every model, but not sure if archicad can work well fixing this things without wasting too much time, so i dont know if its maybe better to fix it with photoshop, or saving 3d views in .DWG and removing manually extra lines. Any help much appreciated!.
Lingwisyer
Guru
The break in the wall on the right side maybe caused by a few things. If the parapet is made as a morph, you are stuck with the line. If not, I maybe caused by the two walls being different building materials, out of line due to inaccurate drafting and being on layers with different intersection orders.
Ling.
