Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Archicad Firm Directory
Hi all, hope that im placing this in the right place..
Does there exist, or will there exist in the future, any sort of directory by region or what have you of firms using Archicad?
Im curious to find out firms in the Chicago land area that use Archicad and Im having a really difficult time doing so.. Im sure most firms dont want to advertise their competative tools, and Ive considered trying to find/calling a reseller to ask (but would that be rude?)
If anyone has some ideas how to locate Archicad using companies in Chicago, your help would be much appreciated! Thanks!
Link
It has been discussed before but no public list exists.
As for contacting the local reseller, I guess it depends on why you're looking. If it is not competitive, they should be happy to help you, and I'd certainly recommend contacting them.
If you're looking for work, you could also try the job board.
Link.
yes best to contact your local reseller, normally they like to help connect other users
