Antonio Borrero
Archicad Live Connection - “select one … in Archicad”
Hello I have the same problem that it is reported here "I would like to connect grasshopper and Archicad to finally use the advantages of both programmes. Unfortunately, after successful installation and successfully linking both documents, I’m not able to set item inside grasshopper.
Normally the Archicad window should be the selected one, but on my Mac its the Rhino7 Window itself.
I am using AC25 and Rhino7"
https://discourse.mcneel.com/t/Archicad-live-connection-select-one-in-Archicad/133010
I Wonder if someone can help me with this
JN
Hi!
I have the same problem as Antonio Borrero, when selecting objects in grasshopper to link from Archicad it is the rhino window that appears, running latest versions AC25 and Rhino 7. Also no objects like columns, pillars, slabs and so on will appear in Archicad efter setting it up in grasshopper.
