Archicad to DWG Problems.
Everyone in my office uses AutoCAD. So I have to convert all the projects to DWG format. However, the methods in most places are not exactly the right result. Either the measurements explode, or the walls come in blocks. I don't really have a chance to make an adjustment(export settings) like it's drawn with AutoCAD?
1 Solution
Have you looked at the DXF/DWG translator settings?
You can set up as many translators as you want and you choose which one to use when you save the DWG.
Don't ask me what all the settings do though.
Go to post
ok i am not asking and thank you
