Associative label leader line default length
SeaGeoff
Ace
In the process of building an office template I spent some experimenting with various associative labels. When using the ID setting I couldn’t find any way to adjust the default length of the leader line. It’s probably hiding right under my nose. TIA for any help.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
1 REPLY 1
fuzzytnth3
I suspect you can't modify it via the object settings as I found a related problem with the auto label http://archicad-talk.graphisoft.com/viewtopic.php?t=3720
If you have a rummage in the 2d script it shouldn't be that hard to add a parameter to all ow you to vary the distance. It's been annoying me the last couple of days as well so if I get a chance tomorrow I will have a look and see how hard it is to tweak.
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
