2022-08-26 03:43 PM - edited 2022-08-26 03:44 PM
In AC26, when transferring attributes from walls and columns to others, the walls and columns height does not adjust.
This works fine in AC25.
Help Anyone.
2022-08-26 04:04 PM
Check your Element Transfer Settings.
2022-08-26 04:15 PM
That ( Element transfer settings ) can be exported from 25 to 26?
2022-08-26 04:33 PM
I did everything I am capable of including that.
2022-08-26 05:03 PM
I believe the element transfer settings can be exported and imported but you may need to open the file in AC26 first, then export them and then open your new file and import them.
2022-08-26 05:05 PM
Have a read of that.
2022-08-26 05:09 PM
Nice trick thanks @Lee Hankins .
2022-08-26 05:29 PM
Thanks everybody.
The the problem is unique to the file I'm working on.
Thanks.
