AustralianEssentialLibrary.pla Relates to my Post Below
Okay,
Good idea to read my post below to get an idea of whats going on.
I have found a library titled AustralianEssentialLibrary.pla (using ArchiCAD version 9) and I HAVE FOUND WHAT I AM LOOKING FOR with the UAB's in this AUS library- it has a function called "angle of roll" where you can change the cross sectional angle of the U.A. Beams. Now I have tried to copy and paste the beam from the AUSLIBRARY into the other drawing however it says that it is a missing object.....SO, how do/would I export this beam into the other drawing? Or how do I combine libraries? Please Help!!!!
1 REPLY 1
David Maudlin
Nuggy:
Go to File>Library Manager..., click on the "Local/LAN" tab at the top and in the left pane navigate to "AustralianEssentialLibrary.pla", select it and click on the Add button, then click OK. This will add this library to the project you have open. For more information about managing libraries, see the ArchiCAD Reference Guide.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
