ā2007-12-05
03:33 PM
ā2023-05-23
05:03 PM
Rubia Torres
ā2007-12-06 03:06 PM
ā2007-12-06 07:57 PM
James wrote:The erratic nature makes me wonder if it is an execution order issue. The correct order would be: update all drawings on Masters and then update all Masters and Drawings on Layouts. Perhaps some layouts are updating before the masters and others afterward, but the masters still update after the other layouts.
It's internal, and while I haven't tested an external drawing, it would surprise me if it worked better. I don't think it's the update itself that's failing, it must be something to do with redrawing the layouts themselves.
ā2007-12-06 08:11 PM
Matthew wrote:Sort of
(Am I making myself clear?)
ā2007-12-06 08:16 PM
Matthew wrote:Ummm... duh? Figuring out the internals of why a bug is a bug doesn't help us here, and is kind of GS's expertise, right?
The erratic nature makes me wonder if it is an execution order issue...
ā2007-12-06 08:21 PM
Karl wrote:it's human nature, Karl! I'd never sit here if I didn't try to figure things out all the time, wether really useful or not - if i was considering usefulness, i'd probably fall into the greatest/worst depression ever known!
Ummm... duh? Figuring out the internals of why a bug is a bug doesn't help us here, and is kind of GS's expertise, right?š
ā2007-12-06 11:07 PM
Karl wrote:Yeah. It does sorta seem it should occur to them. Sorry if I was stating the obvious. I am generally not one to spend too much time figuring out why computers break. My rule is use it 'till it breaks, fix it and use it 'till it breaks again. If in the process one figures out why it broke, the informationMatthew wrote:Ummm... duh? Figuring out the internals of why a bug is a bug doesn't help us here, and is kind of GS's expertise, right?
The erratic nature makes me wonder if it is an execution order issue...š
ā2007-12-06 11:17 PM
Matthew wrote:It never occurred to me that you could re-arrange the drawings in the Drawing Manager - is it possible to do that?
n this case I think this may suggest a workaround. If the drawings are ordered appropriately in the drawing manager it might cause it to update the masters first - assuming publisher runs the updates in the same order.
ā2007-12-06 11:22 PM
Thomas wrote:Alphanumerically.Matthew wrote:It never occurred to me that you could re-arrange the drawings in the Drawing Manager - is it possible to do that?
ā2007-12-06 11:25 PM
Matthew wrote:So you mean by renaming them you could get the update order you want. Interesting!
Alphanumerically.
ā2007-12-07 12:19 AM
