Paul King
Mentor
Boolean Ghosts
Hi - I have certian areas in a large model that are haunted!
Whatever new wall I place in these areas has a boolean subtraction done to it, subtracting another object that does not exist on any layer or on any story.
How do I locate & delete these phantom boolean operators, and why would they interact with any walls placed on these locations - I have not defined these new walls as targets in any Boolean operation.
Is it possible to have negative or ":antimatter" objects that are only revealed when coinciding with a positive element?
- Looks like that is what I have here!
Spooky!
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
2 Replies 2
Post a screen shot for us, perhaps?
Are the 'subtractions' rectangular and about the thickness of a wall? If so, the answer is easy - layer intersection priorities. If not, show us a gif capture to send to ghostbusters! 😉
Paul King
Mentor
Hi - answer was that I was not as thorough in checking as I thought ...No boolean involved.
- I had an early assemblage of small columns & beam objects stuck on a GDL Construction layer which is always turned off - but these were still interacting with walls coincedent in space - atcually turning them into swiss cheese!
Why switched off objects should interact this way I don't know - do intersection priorities apply to this situation?
Cheers
Paul
