Break Line
Is it possible to draw a Break Line in Archicad? I’m trying to figure out how to break a wall so this Break Line symbol appears...? Hopefully I don’t have to draw this Break Line symbol manually...? Is there any simple way of drawing up these Break Lines?
Many Thanks!
4 Replies 4
You could draw it using a Polyline.
Then you could add a white fill below it to cover the Wall.
You can also save them as an Object for later use.
Thanks for replay…ok…will try!
James Murray has one for download on his blog here -
http://www.onland.info/archives/2005/06/cutline_jm10.php
It's also in the object depository.
Depository > 01 General > Graphic Symbols
Doug
