Brick detail around window
I was wondering how to model this detail around a window. There would be stucco in the 1/2 round above window. Also how to show a quoin corner.
Thank You for your time
Brian
2 Replies 2
Try first the GDL object that you have in your ArchiCad directory, or search on the famous Internet.
Or you could build this using slab-tool, then go to 3d window in parallel perspective and set the camera to look from above and then save it as GDL object.
Or the hardest way is too build it from scratch in GDL language.
Brian,
This window with brick souround was made with
AC 10 library parts. see attached.
Peter Devlin
