CAD2004
now ive upgraded my architectural desktop 3.3 to 2004 the merge function does not seam to work. Ive my plans in CAD where i was about to merge into archicad8 but it doesnt bring up the window that it normally brings up. any ideas?
8 Replies 8
ArchiCAD does not yet support AutoCAD 2004 DWG files. Save to AutoCAD 2000 or r14 formats.
can you do that in ADT2004, when i looked through the save as list i only had 3 options.
dwg
dws
dwt
can you save it as 2000 format?
I would expolode ADT 4 objects priorr to saving as 2000 version...just in case
Regards
Piotr Dobrowolski
Brendan GSUK
Graphisoft Alumni
Graphisoft Alumni
You could always try the IFC import/export utlity. There are beta versions of IFC 2x add-ons available for both ArchiCAD and ADT 2004.
The ArchiCAD version is available on the GS website at
http://www.graphisoft.com/support/ifc/beta_download/
and for ADT you should visit
http://www.team-solutions.de/
The ArchiCAD add-on is available free of charge, but there is a charge for the ADT add-on (€398). I have tested the output from the ADT add-on imported into AC and while there are a few minor issues, the results are pretty good.
Brendan
__archiben
we have just successfully opened a autocad2004 document with autocad2000. proxy graphics for archiCAD anyone?
from that it's easy to save as a 2000.dwg and into archiCAD...
hth
~/archiben
b e n _ f r o s t
stefan
ADT 2004 supports saving as DWG in different flavours. Weéve had some troubles with this as the list of exporters in our classroom was different when launching AutoCAD with a different set of startup commands...
AutoCAD 2004 Drawing (*.dwg)
AutoCAD 2000/LT2000 Drawing (*.dwg)
AutoCAD Drawing Standards (*.dws)
AutoCAD Drawing Template (*.dwt)
AutoCAD 2004 DXF (*.dxf)
AutoCAD 2000/LT2000 DXF (*.dxf)
AutoCAD R12/LT12 DXF (*.dxf)
2000/LT2000 should be the best format for ArchiCAD.
Archicad-user since 1998
my Archicad Book
doh, big efforts to get the latest software to find they dont work together. uninstall ADT2004 time back to 3.3 hmm
You need to use the "Export to Autocad" function and not a save as to get the drawings into a 2000 format from 2004.
This gives you several different formats to save into.
