COPY AND PASTE PROBLEM
1. Why does it takes so long to COPY "anything" to clipboard ??????
2. The same thing is about updating drawings in Layouts, sometimes up to 10 minutes !
4 Replies 4
Does it happen with all the files or one particular file?
BTW Upgrade to Hotfix1188 AC10
I cannot say for sure for every files,
but it take place in my Current Project.
I suppose, that it occurs when I coping something (even a line) from
PLAN WINDOW. It looks, like archicad is sorting out the whole project to find those selected for COPY elements.
In a new clear project it works immediately.
It makes me angry!
PS Hotfix? No.
SPINCODE wrote:
PS Hotfix? No.
You must upgrade to the latest hotfix to expect help on something like this ... 100's of bugs are fixed... If the problem still exists, then post again.
Karl
Karl wrote:
SPINCODE wrote:
PS Hotfix? No.
Karl
Yes, i've made this upgrade, but << NOTHING CHANGED >>
Here is my assumption:
It's no object, that some story has no objects at all,
when I copy just a circle from it, Archicad will dig over the whole file.
This is his (Archicads) internal architecture.
And Nothing can be done.
When you press Copy button in a Plan window, he began a query to a project database, to find those elements, that are selected.
another thing happens when press copy from Detail Window -
It works much more faster, because Search range is limited to
only this window data.
