CUSTOM WINDOWS
I am modelling a project as per image attached. There are a number of glazing windows, same width but with a sloping top, aligning with top angled parapet.
Apart from using curtain wall tool, is there any other way to create a series of windows as per the image?
Thank you for your helps
1 REPLY 1
If you want all separate windows, then just use the trapezoid window and set the size for each one.
