CUSTOM WINDOWS
I am modelling a project as per image attached. There are a number of glazing windows, same width but with a sloping top, aligning with top angled parapet.
Apart from using curtain wall tool, is there any other way to create a series of windows as per the image?
Thank you for your helps
If you want all separate windows, then just use the trapezoid window and set the size for each one.
