Can I create a "sketchy" view of a floor plan?
My employer wants to take a floor plan and give it a "sketchy" look, like you would in a 3d view. Is this possible? I found some information on doing this (http://www.graphisoft.com/support/archicad/archiguide/2003january.html)
but it's an old post and seems rather lengthy and difficult. Any help???
4 REPLIES 4
Dwight
Right. Complex an understatement but a beautiful result just the same.
1: Make a new line type that is squiggly.
2: Explode your floor plan but retain primitive elements.
3: Select all the new lines resulting from the explosion and Drag them to a new place /cut to an independent window
4: Change the line type to the squiggly one.
Cigraph makes a sophisticated appplication called ArchiSketchy for this purpose.
Dwight Atkinson
Thank you Dwight.
Yeah,
http://www.archicadwiki.com/TechNotes/Sketch_Rendering_from_Floor_Plan?highlight=%28sketch%29
was Bert and me with rewrite by GS in 2003. It's actually way easier than that now, with plotmaker long gone. The sketch render gives a good effect, but if you want something that is to-scale, other options like Dwight's suggestion, are simpler.
The trick of the tip is that ArchiCAD cannot display lines in 3D (unless generated by a GDL object). But, if you open a dwg as an object, the lines of that object will appear in the 3D window and thus can be rendered with the sketch engine. (They disappear with LightWorks.)
AC 28 USA and earlier   â€¢   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
