‎2007-11-07
07:53 AM
‎2023-05-23
05:04 PM
Rubia Torres
‎2007-11-09 06:18 PM
tina_yi wrote:What is the source of your bottle object? Are you scripting it yourself? RESOL or TOLER might be the way to reduce the number of faces, but it depends on how the object is scripted. If there are no arcs in the script that make the object, then RESOL or TOLER will have no effect.
It's me again, I've try to give the bottle thickness but still not work,how do you down the somthness? I go to 3D script to change the resol 36 to 20 , is't the way to do??
‎2007-11-12 06:35 AM
‎2007-11-12 09:06 AM
tina_yi wrote:If I remember correctly, the smoothness of a profile using the Profiler tool is controlled by the Magic Wand settings. Once the profile is created, the smoothness is fixed - best to get it right from the start. RESOL or TOLER in the script won't make any difference.
Hello Ralph,
I do my bottle in AC add-on library tool,I think It's profile tool(because my AC is Chinese version so I'm not sure the actual name). I don't see any
parametric to do with smoothness, so I open my bottle in GDL object to chang the setting,but there is resol show only and it's not work, and I don't know how to script.
‎2007-11-15 11:16 AM
