2017-03-24 08:23 PM - last edited on 2023-05-25 05:55 PM by Rubia Torres
2017-03-25 03:40 PM
2017-04-04 01:56 AM
Neil wrote:Graphic Overrides, introduced in ARCHICAD 20, can be used to set a uniform white surface on your model. In the default AC20 USA Templates there is a G.O. combination called "White Model" just for this occasion. If your file does not have the "White Model" combination you may open one of the default AC20 templates and export it. Then open your file and import it.
...is there a setting to turn my Open gl into a black and white sorta gray scale setting
