ladystarlight
Change story number, not its project level (0 to 1)
Hello
Can I change in story settings name 0 to 1, and it's important that everything to be linked with changes name for example  zones, sections markers and etc, is it possible?
3 Replies 3
Rubia Torres
Hi @ladystarlight,
Do you mean the story number or its name?
You may refer to this thread. I believe you seek for the same answer.
Rubia Torres
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
ladystarlight
Thanks for reply, I found the solution, I add one story with 0.001 Height so 0 story starrts from 0.001 and name automaticaly is 1.
You should find storeys can have a 0 (zero) height as well.
