Can someone please explain the logic behind the behavior when multiple objects are selected and the layer pull down is changed in the info palette. Only one object type is changed at a time. Why not all at once?
This frustrated me until I realized that the new button next to the layer pull down brings up the Edit Selection Set palette which let's you change them simultaneously. I assume I always had this power but just didn't know it.
So I'm no longer frustrated but no less puzzled.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
